So whenever I restart the PC, I can't search for files immediately and my desktop icons are blank. My wireless icon also shows it's not connected. This happens for approximately 1 minute and then the PC is fine.
It gets even weirder as if I Windows Update to latest, I then can't click the Start button till after a minute has passed.
I've tried from multiple fresh Windows installs and it always seems to happen after awhile. However, I should say that this only happens after restarting the machine and if you shut the PC down and re power on, it's usually fine.
I've booted the machine into Safe Mode and it works perfectly fine from a restart there so don't know if that helps diagnosis.
Software installed from fresh OEM Win 8.1 USB install:
1. Classic Shell with skip metro screen.
2. netplwiz configured to allow auto log on.
3. dxwebsetup for DirectX 9.0c
I restarted after these installs earlier and it seemed fine but maybe after 2-3 restarts they might have been the problem but I doubt it.
Someone told me this might be a Windows Update error but I've not installed any. Maybe MS is secretly installing some packages or something?
