So my question is are my results standard? I know my previous results were good, but these results from realtemp are over 10c hotter![]()
Mine gets in to the mid 70c's @1.23v 4.5 ghz, but only got 2x 240mm ek pe rads at the mo, just about to put 2x480's in the loop.
Your temps seem to be as they should be.
Sorry meant to reply to this earlier! Well I have 2x480. Bottom rad in push pull and top rad in pull on top of rad/case. If you're getting better results with only 240's surely something's wrong? Can you do a quick IBT run for me and list your core temps? I'd be very grateful![]()
Sorry should have put on my post, that was using real bench stress test.
You are using more v core than i, my temps start to ramp up in to the low 80's when using 1.3 core
I managed to decrease temps by 10-15c by lowering clock to 4.6 and voltage to 1.245 volts! Still not what I expected but much better. Highest temps on IBT with ambient temp of 24.5c had a max temp 71c.
If stable I would say that is excellent - my 5960 wont even do 4.6.
Mark
I'd say anything under 1.3v and stable is a win for those clocks. Your temps look good as well.
This was by using Asus Suite 3 with the 1.25v cap. So Asus suite tried to get it stable at the maximum possible speed at that voltage. It's seems to have clocked my RAM down to 2400 from 2800 though
