***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Do most Vapers also smoke cigarettes?
Interesting article here http://onlinelibrary.wiley.com/doi/10.1111/add.12730/epdf
I do. But not through choice. I don't smoke cigarettes at all when I'm on land. Unfortunately, they aren't permitted offshore, so I have little choice but to smoke when I'm at work.
I for one don't, i picked up vaping back in 2012 to get off cigs and weed, haven't touched either since.
I would have been the same had it not been for my work. Grrrr. Well done though.
If u make ur own juices how do u make the flavours.
Flavour concentrates. Generally 20% concentrate is about right, but you can mix up different flavours to your hearts content. And there are MANY different flavours out there.
What RTAs work well with Temp Control. I just cannot get a build in this Lemo2 that doesn't taste like butt.
I did a dry cotton test and it didn't burn the cotton till 460f so set the Sigelei to 440f to start with and it tastes like nothing but cotton, even dropping it right down to 200f I can still taste cotton
Both my subtank minis, Squape R. kayfun Lites V2 & Goblin Mini all work perfectly with tc, on my Sx350 M Class, Istick 40 watt tc & Sigelei 75 watt.
Hope this helps?
Cheers all
Another Vendors day today on UKVT (UK Vape trades on FB).
Some bargains to be had, just picked up a TC iStick 40w for 20quid!
Vapor-royalty.com for anyone interested. Glad to pick up a TC mod for out and about :-)
Hope this helps?
Cheers all
How do you find the goblin mini?
Found it yesterday and thought it may be a good tank, but then read a lot of people complaining about the tiny build deck and the fact that it leaks through the Air feeds!
the build deck is VERY small for a four post system, nothing an experienced builder can't over come.
Mine hasn't leaked on me yet, I'm on the four tank with the same build. What it does do is pour out the extra juice after I've filled it and builds up condensation. but that's likely down to the way I'm filling it.
Hope this helps?
Cheers all
Will give the Subtank a go later, need to grab a Nickel OCC coil off a friend to try in it as well as I got him to grab me one while he was going to our local store
Just got my istick 40w TC. No idea if I'm doing it right.
28 gauge ni200 at 0.12 ohms. Set for 420f. Using bacon cotton.
Vapes fine but keeps hitting the temp limit and cotton is going slightly brown.
Shameless self bump :D but I'm about to recoil, anyone have any pointers?
From my little experience, build low with the tc40, the .15 occ coils were weak for me, 0.07 on the rba+ is a whole other world better, though I'll be ditching mine completely when my D2 arrives later in the week.
Ah, fair enough. I'm sure i could get past the small build deck, but the leaking thing worries me a little, may wait to see if there's a revision to it
The airflow is very good.. highly adjustable and it has an affect on the vape.. I've been using it all day. You will; Or at least I do get juice coming out when you fill the tank, but that's could be the way I'm filling it but after that no juice at all.
The tank on the hurricane is a joke, they have been breaking with normal use and without tank cracking juice. You will need to get the metal one pretty much straight away.
The bottom fill screw is what I'll likely find annoying, that and my sausage fingers on that small deck :p
Yeah, I expected more from the hurricane, a £120 tank made from PMMA, no thanks, if they insist on PMMA they should at least be throwing the metal tank in as part of the package, not an after purchase.
Think I'm going to start with the Aromamizer RDTA, the big thing I want from an RTA is airflow, I cant MTL any more, makes me cough and splutter!
with the nautilus mini im getting is there any ejuice i shouldnt get also what nicotine level is best? Usually i got 11mg.
iirc the nautilus mini uses either 1.6 or 1.8 coils, if you're currently happy with 11mg you'll be safe enough staying in that 10-12mg region IMO.
I can still MTL 12mg on a Subtank Mini 1.5ohm coil after sub-ohming 3mg so someone used to MTL 11mg should be fine
I've used everything from 18mg 100% PG to 3mg 80% VG, they all work fine. Current favourite is 3 or 6mg 60VG/40PG or 70VG/30PG juices at 13w with the 1.6 coils. You'll get way more vapour so you can probably bring down the nicotine levels. I'm so used to 3 and 6mg now, i tried 12mg in the Nautilus Mini the other day and it was way too harsh.
You may find that you need to vape less or have a lower nic level as it has more productive coil system. the BVC is one of the best MTL coil systems for factory made coils.
Status
