Ideally you'd have a valve coming off a T of Q block at he lowest part of the system. So for me that would be the bottom radiator. Unfortunately as the bottom RAD is quite big even for a 900D I couldn't fit the valve and Q block, unless I left the back spare PSU case grill off. So if you look at my pic you'll see the outlet (bottom of res) with Q block going to the acrylic pipe and valve at the bottom which you can't quite see, whilst the other Q block connection is going to the flow meter.
Basically I have a spare acrylic piece that I made which bends off the valve once connected via compression fitting and that basically extends out of the case and down. I use it when I want to drain and take it away at all other times.
I will take some pics tomorrow if you want, although I'd not suggest doing it my way as the bottom rad basically still has fluid in it, which means you still have to tip he system.
I'd suggest Primochill fittings and Acrylic. Top quality and better than the male to male 1/4 XSPC fittings I have in my system (only ones in stock at ocuk but VERY cheap). You can definitely tell the quality difference
The Primochill Ghost compression fittings come with a handy little tool to tighten the fittings, but it is a bit flimsy so be careful not to break it!
