The Gentleman's Undergarment: Tight vs. Loose
Caporegime
13 May 2003
Warwickshire
What do the 'members' of OcUK prefer to sport downstairs? Tight or loose?
I've always been a boxer man personally. I can't stand the feeling of tight underwear.
I've tried briefs / trunks and they always ride up my leg. I'd rather have little Participant flopping about and run the increased risk of a wedgie, than have the feeling of legs riding up my thigh and reduce blood flow to my plums.
Maybe we should put it to a 'pole' ;).
boxers was a 90s thing and I never changed.
I couldn't do tight underwear and sweaty balls, I get that when I wear cycling shorts. I certainly wouldn't want it all the time.
also my member is bigger than the average so I would likely need to keep repositioning it to be comfortable or to stop it rubbing against my leg and getting excited.
I did buy some boxer briefs for the bedroom but meh
Somewhere inbetween - I like a bit of support but not tight (usually wear boxers/hipsters depending on style/fit).
You missed the one about not wearing any underwear, seems a lot in the older generation.
Can't see the point of pants to be honest, as long as you're not wearing a kilt or a cross dressing weirdo you don't need them and also they're definitely not healthy.
To separate your *** and **** from your trousers maybe? And the outline is a lot more graphic if you're not wearing anything underneath. :p
Don't wear any at home though. Just wear shorts or joggers and let it hang.
In before mankini.
Boxers here, I walk 15-20km a day in jeans, and it rarely drops below 30c, so I can do without the chafing.
Don't where any at home though. Just wear shorts or joggers and let it hang.
the argument that you need fabric between **** and trousers is stupid because why not also have a fabric between **** and pants where does it end.
The doctor on the telly said no pants is the way to go so I did.
