Fan controller - is it worth it over asus mb software?
8 Dec 2012
UK
Hi all,
I currently have all my case fans and my cpu fans controlled using the Asus QFAN feature which I do like.
However I just saw a review on the Bitfenix Recon and the NZXT Sentry 3.
I know I can use Asus software to create profiles for my fans as well.
In your opinion are fan controllers worth it over Asus software? If so, what fan controller would you recommend and why?
Thanks in advanced for all your comments.
Please don't get the Bitfenix Recon its the worst controller iv ever used.
Ramps fans to max randomly the included software is not good at all and in all a pain to use.
I moved to the NZXT sentry mesh its just manual sliders but works perfect
I prefer the motherboard fan controller software as you can set up temperature<->speed curves etc.
If I were running a lot of powerful fans then a fan controller would be the way.
Thanks for the feedback considering the Bitfenix option Andy.
Archeum; is 4x 140 fans (2 front intakes and 2 outtakes [1x rear and 1x top placed at rear]) considered by you "a lot of powerful fans"?
Thanks
It depends on the fans and the motherboard, most MB headers are 1A so if your 4 fans are less than than you are fine. Where fan controllers come in their own is, for example, running push/pull watercooling where you may be controlling 8 fans on one header.
Might just download Asus's AI Suite and stick with using xFan instead then.
Currently I run all my fans off fan connectors that use QFAN. The 2 rear off a chassis fan#1 pin head and then the 2 front off the other chassis fan#2 pin head.
I've had this one:
Lamptron FC6
I've had 17 fans in my build so fan controller was a must.
What's nice about this one is that you can remove the faceplate, paint it in whatever colour you like and put it back. I had mine in red.
That doesn't bother me.
How accurate would you say the sensor readings compared to actual temps? i.e. I would put one near my CPU, one near the GPU, one near HDDs and one off mb somewhere for ambient.
I use speed fan. It's free and very widely compatible and controls 9 fans across 3 headers. Bit of pita to understand and set up but afterwards it's effortless silence.
I've had this one:
Lamptron FC6
I have one of these two, i just ordered mine in black so no need to paint it
Great controller
