- 14 Mar 2011
Hey all,
Foreword - I know close to nothing about cars; I drive one and know roughly the basic names for a few of the parts but that's it (the wheels are the bits that touch the road, right?)
So anyway, picked up an Astra J last week (new-ish, 62 plate with ~30k on the clock) straight from a dealer. Was away visiting family over the weekend so had a chance to give it a decent test at speed etc... As ever I noticed a few things which I'm not sure about; which brings us to now:
1. Most concerning - once you get up to higher speeds there's a pretty distinct spinning high-pitched whine - it sounded to us like it was coming from the rear wheel area. I couldn't manage to pin down exactly what was causing it; at one point I thought maybe it was worse when turning the wheel to the left, but I'm not so sure about that - and possibly it goes away when you tap the brakes but comes back again. It didn't do it constantly either - seemed like it would do it for 10 minutes or so and then it could be hours before it did it again.
Someone mentioned it could be a wheel-balancing issue? I did also notice when on slower roads the steering appears to be pulling ever-so-slightly to the left as well; not enough to feel like you're really fighting against it constantly but if you test it letting go of the wheel there's a slight drift there...
2. First car I've owned with cruise-control... had a bit of test and it seemed to work fine; set it at ~70-80 and could feel it was working as it was supposed to. However a while later I tried to turn it on again and it just didn't seem to want to work... the dash light was indicating that it was active, but then when I let go of the gas I could feel that the car was slowing down and then the light would go off again. I don't think I was hitting the brake by accident or anything so I'm a bit confused there -> does the cruise-control "remember" the speed you set it at previously or something and I've somehow got it set to something silly?
3. The stereo is super loud... too loud... the radio as always is louder than everything else, and with that even volume 1 is ridiculously loud. I can't seem to find much in the way of options via the controls on the console, just an EQ and a few very basic volume settings (one of which is the "minimum startup volume" which can't seem to go lower than 13 - which will blow your ears off if it's the radio)... Does anybody know if/how I can access some sort of advanced settings? I'm sure I must be missing something because equally I can't change the temperature readout to Celcius instead of Farenheit either
Contemplating taking it to the independent garage I normally use and just asking them to take a good look at it all, but any tips/advice would be appreciated as well
		 .... (we made them pump them up and said we'd be back in the morning if there was any sign they had flattened overnight)
