If you're running AMD on Windows 10 and Freesync suddenly stops working, check your windows update history. Mine just silently installed 15.2 over the top of 15.7. Went looking for it in the Windows update history and there it was.
I am currently having a freezing issue with both my O/S's so unable to diagnose, but I see comments about a 'run-once' registry reference not being updated.Guys are you seriously saying that there is no "download updates but let me chose when to install" option for Windows 10?
If so I find that very odd.
Depends on the version, "Home" users (or whatever it is called now) are at the mercy of automatic updates.
hopefully it doesn't pull that crapdoh; good thing I'll have prohopefully it doesn't pull that crap
Here's how you can set it to show the options for the update:
http://www.markspcsolution.com/2014/11/disable-automatic-update-in-windows-10.html
I will be grabbing a DVD. Windows upgrade is historically a complete hash.
I've pre-ordered a key, should be here on the 29th or 30th i hope. I would need to buy a Drive to use the DVD.
Have MS stopped that force auto update with Win 10? I read an article that it was causing so many issues with NVIDIA users.
I thought I read that physical copies of Windows 10 were going to be coming on a USB stick, not a DVD.
