Recently got a 295x2 and was struggling for where to put the rad i wanted optimal cooling without heating up the cpu so i decided that the only real place to mount it would be outside the case! Some will hate the basically bodge job nature of this idea, but i wanted to cool it better for zero cost. I like to mess with things so its worked out rather well.
I had to send the cables through the rear of the case, i couldnt/didnt want to take them off so made a slot in the case just wide enough for it to fit without the fan on. i made sure all the edges were smooth to not damage the pipes. after that i had a small piece of angled aluminum which i drilled and then drilled the case simply put it all backtogether adding a second old fan i had laying around.
Firestrike ultra topped out at 65c with a modest overclock on the card
Core 1080
mem 1340
I had to send the cables through the rear of the case, i couldnt/didnt want to take them off so made a slot in the case just wide enough for it to fit without the fan on. i made sure all the edges were smooth to not damage the pipes. after that i had a small piece of angled aluminum which i drilled and then drilled the case simply put it all back together adding a second old fan i had laying around.
Ill take it futher when time allows.
[/URL]
[/URL]
[/URL]
Core 1080
mem 1340
