Titan X to 980 Ti, Insane ?
Do it for the lolz :p
My Titan X can do 1450/8200 quite happily :D
*EDIT*
Gaming with 1479 on the core and 8208 on the memory in Shadow of Mordor at 4K max settings completely stable :)
Mine sits at 1400mhz but wont take any extra voltage at all and hits the power limit even 5mhz over that. Its weird it just dosnt seem to like any extra voltage but its stable in every game/bench Ive run except crysis 3, which for some reason likes to throttle it by 20mhz or so.
Like the sig Greg!
Thanks :D
Mine doesn't like extra voltage either. A shame really and flashing another BIOS would sort it but it just doesn't warrant it and it is plenty fast without the volts.
Not something I would entertain at all. Less SMs and less VRAM. If you were looking at custom AIBs for air even then it's moderately worthless. Maxwell headroom is relatively limited above 1.25v.
