Writing a cover letter for Apple Product Design Engineering internship
[FnG]magnolia;28370984 said:
Remove all the interesting design stuff, make it plain and efficient looking, remove some of the functionality, and tell them that it will retail for $3,299 and command a 1700% margin.
Thank me later.
Exactly this, and be sure ti write the letter in the blood of their korean enemies and the tears of their chinese employees. Make it clear this is what you have used to write the letter, and that both are fully utilizable and almost unexhaustable resources.
Ask them to consider a north korean partnership for even cheaper more exploitable workforces.
Ok first off... I don't know how old you are or what qualifications you have etc so I'm just judging based on the image.
The letter, a cover letter is normally quite formal in it's appearance and approach.
Now the design on the other hand and this is likely how apple design staff would see it. They who will likely have 100's if not 1000's of applications too so you need to stand out.
As a qualified product designer who works in the field on a daily basis I'm just not sure what's so special about that design. It doesn't have a pleasing design to me (it does look like a bread bin as mentioned), it's much bigger than the ps3 and wouldn't fit in most people's home decor theme.
From an engineering standpoint (we had to do a basic level of this too on my course), it's not really that impressive either, it's literally a few cut blocks of plastic (likely planned in software then machine cut) and a 'curved' piece. The metal sheeting on top looks like the cheap stick on stuff you could get for cars although this could be down to the image and your screws could have been counter sunk, there's enough depth in the plastic sheeting.
You say you've focused on cooling the ps3 yet you've bought off the shelf parts which don't take any engineering skill to put together (most of the hardcore pc users on here can do it) rather than showing off your engineering skills off and made a custom heatsink to aid cooling. Not to mention Apple internals would never be that untidy.
If I'm completely honest, I'm just not sure it's up to the level that Apple would be looking for, they can literally pick and choose the best of the best.
Apple products are just engineering porn when it comes to how well the internals are designed and put together. So clean and minimal
Yep, stuff like using stepped batteries is just so neat, and laser cutting tiny holes in aluminium just so they can shine a led through the metal :cool:
This level of design engineering is light years away from some guy shoving centuries old mechanical watercooling into a box.
Anyone can make a product, only Apple seems to look at every single aspect of a design and improve everything.
wasn't that an LG innovation?
yep, pretty much all the innovative aspects of apple design is usually from someone else, they just put it to good use in a nice package.
I like to think of apple more as a very nice packaging company rather than a design/engineering firm in the strictest sense. I can't even think of anything that apple actually designed themselves from scratch....
Probably, the idea of squishy batteries has been around for decades. Apple don't invent everything and some things have patents all over them already, they are just choosing to re-look at every aspect of a design.
but the apple batteries are just plain normal rectangular ones?
It looks like a bread bin with lights?
I think John Lewis would be more interested.
Thank me later.
:D:D:D:D
Meh I can't find the image now, but I remember seeing something the size of an iPad or a Macbook that was having the insides milled out and the battery was fitted in around that. It wasn't the LG because that was in two layers and this had three steps to fit inside a curved casing.
some of the laptops have 'layered' rectangles to fit into the sloped design. It's not really anything new, it's just a new packaging at best. Pretty sure someone else came up with the process to do it because Apple doesn't make batteries :o
bitslice, you're likely thinking of the new macbook
OP.. RIVETS.
One of the things I would have throught apple would pick up on is the attention to removing aesthetic interference by designing new ways of connecting things etc.
Highlighting this would be interesting then..
Maybe it should have been a bread bin which also makes toast in those slots,
with a light inside so you can see if your toast is burning.
Apple needs a toaster in their gadget lineup.
with an app which counts the calories per slice.
