Unlike the previews w10 does not have internet explorer.
You could just try downloading internet explorer.
http://www.microsoft.com/en-gb/download/confirmation.aspx?id=41628
Open this Registry Key:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer]
Left click on Version, select Modify and enter 9.11.10240.0 in the form field
Try installing an older version like the link.
Or use the opportunity to upgrade to something newer and better. rather than carrying on using legacy software.
http://forums.overclockers.co.uk/showthread.php?t=18683286&highlight=microsoft+money
I had the same issue! There is a fix which has worked for a load of people, but not for me. Worth a try...
I have since moved to Quicken 2013 after finding a copy. It isn't supported in the UK, but 2013 does work fine and I now prefer it over Money. Nice reports, just as easy to use and is modern.
I am considering buying the 2015 version, but a bit hesitant as I won't be able to use one of the major features that I'd like - syncing with my phone - as the app is not available in the UK PlayStore. Once I've found a way around that, I'll consider buying 2015.
Easy said unfortunately. I've spent hours scouring the internet for something as good as Money. Tried GnuCash, YNAB (hand holding much?) and many others, none came close to Money IMO, apart from Quicken 2013 which beats it. Such a shame they don't officially support that in the UK anymore.
There are also a few online, like QuickBooks (also Quicken and is available to UK), but that's more for companies and is expensive (monthly payment).
Thanks that seems to have done the trick for me.I had the same issue! There is a fix which has worked for a load of people, but not for me. Worth a try...
It worked for me too. I wonder how long the fix will last. Are Updates to IE11 likely to render it useless again?
Windows Registry Editor Version 5.00
"Version"="9.11.10240.0"
