Going to get a monitor this week, whats best?
23 Mar 2011
As title, i have been looking on and off for a while but now i just want to get one
Looking at 27" and 1440p (if possible with my budget)
Budget £300-350 at most
I was looking at the dell 27" but i dont think its aimed at gaming. I dont play much fast paced stuff but do play shooters from time to time, mainly into single player these days!
Whats the best screen for me!
BenQ GW2765HT is really nice, though at your budget I'd look at the cheap 4K monitors like AOC U2868PQU, they're also pretty good even though TN. I don't think the jump to 1440p is worth it.
Only reason im not looking at 4k is my hardware wont support it well enough to justify it unfortunatly, so i think 1440p is the highest i can go on my current set up
Stick with 1440p and get a Dell 25 or 27".
I've got the Dell U2515H and its fine for gaming, I got rid of my 144hz TN panel for it and wouldn't go back.
Check badass' site for the u2515h review of you haven't already it's very detailed.
I went for the 25" because the price is great and it's just right for using without any scaling.
Think i may go with the 25" actually, 27 seems a bit over kill but i dont want to think its too small lol!
Also worried i may notice the response time in gaming but i doubt i will? My current old lg monitor is 23" and apparently has 5ms black to black so i doubt id notice any difference at 60fps?
Speaking from experience, I would go for the 27inch 1440p. The extra screen real estate is amazing....for gaming, for movies....couldn't go back to something smaller and in my mind 27inch is the sweet spot for 1440p
Or do i go a size down say 24" but go for g sync and a higher refresh rate? What would you guys do?
Wondering if something like this will suit me and my spec better as i can barely max games at 1440p anyway and maintain 60fps
https://www.overclockers.co.uk/showproduct.php?prodid=MO-022-AO&tool=3
*dont worry, decided to go with the Dell 2515 :) thanks for the help! just ordered it before 3pm for saturday so should i get it tomorrow or was i too late? not yet recieved an email, hopefully its ok!
