Morning all,
I *think* I may have killed my motherboard. I moved it out of an old case into a new one yesterday and it wouldn't power on at all.
When I plug the 24-pin connector in, just as it connects, there is a "click" sound and the CPU fan moved a fraction and then ... nothing.
For reference the motherboard is a GA-880GM-UD2H with an AMD 965 Black Edition. The PSU is a 1000w taken from a lenovo server.
Is there anything else I can try?
- Reset all connections - no good
- Removed everything except for 1 stick of ram, cpu, and cooler - no good
- Removed motherboard from case and tested - no good
- Checked PSU using "paperclip" trick - PSU fan comes on
- Checked case power switch - reseated - no good
- Swapped power switch for one in old case - no good
- Tried shorting the power header with a screwdriver - no good
- Removed and reseated CPU - no good
- Reset Bios by removing battery - no good
