I may of miscalculated..
It's about time psu's came with right angled connectors. it would make things much easier and neater when cable routing. In your case it looks like the heatpipes are in the way as well.
Ouch, a lovely little case (I've contemplated getting one), shame it limits the size of graphics card.
Its very nice, made up with it :)
Owners Club - Some decent info about other peoples builds here. Info on what GPU will fit aswell. EVGA and Gigabyte seem to be ok, just a shame about the MSI :(
Or the GC manufacturer needs to put the PSU connectors on the back of the card. The MSIHD7850 I have in my encoding rig has that, but the MSI R9 280x I have on soak test at the moment, its my nephews BD present (Looks identical to the OP's card) won't fit in my LC17 unless I take the case brace out. So if & when I decide to upgrade or keep the card in there, I'll have to look for a card with rear connectors.
I dont think I could use rear connectors either to be honest. There is about 15-20mm of room between the GPU and my H105i.
Lots of fun with the small form factor :')
I had exactly the same issue with an MSI R9 270x, fortunately the Sapphire variant had side mounted power connectors and hidden heatpipes which did fit
Oh dear what a shwat! :o
You would not miscalculated it if you had asked MSI GPU owners like me with MSI GTX 970 Gaming to gave you nearly accurate measurement of heatpipe height on top of card then you would not bought it and went with EVGA SC.
Yes that is what I should have done :rolleyes:
Ordered the EVGA now anyway so all good :)
I'm sure a few of us have been there... :D
I once did this:
