EK-Vardar F4-120ER (2200rpm) PWM question
Yeh i am going overkill as well for the same reasons as you silence.
Greebo what fan controller do you have?
Congrats on the primo :cool: you will like it, what colour you gone for?
Black and orange. Not my first choice but my x99 soc motherboard has all orange lights on it so orange we go!
Last build was all blue.
Not bought a new fan controller yet. Current system has two fan controllers - Asaka know one and an touch screen digital one. I want to make full use of pwm fans and hubs with the new build.
So open to suggestions as to which fan controller I should go for. I quite like having one I can set up with a fan profile vs temps and just leave it to it tbh.
Oh you guys! I am not having a single 120mm fan on a rad in my primary build(s). Only 140mm and 180mm fans!
Greebo: Yeah, Nemesis GTX is tremendous. But unless you are ok importing it, you have to wait until their new European retailer is set up. As far as controlling these goes, powered PWM splitters and 1-2 headers should help.
I got the same mobo, can not fault it apart from fan control is poor in bios when used with the primo pwm hub that makes 3 pin fans work like pwm fans.
I got a Aquaero 6 XT Fan Controller, but its rma'ed atm waiting for it to be sent back.
The Aquaero does every thing, pump control, fans and flow etc.
