Ok so, I’ve accumulated all the parts i need to fit my first ever loop, I’ve not seen much mentioned about filling / draining loops though.
So, what would I need to be able to Fill and Drain a loop, is it as simple as just put a pipe at the top / bottom of the res (res / pump all in one) ?
What do i use to stop the flow out of the drainage pipe? I had a quick browse through the water-cooled parts but didn’t see anything that jumped out at me and said “YOU THERE BUY ME, IM WHAT YOU NEED”
The setup consists of;
• XSPC AX360 Triple Fan Radiator - White
• XSPC AX240 Dual Fan Radiator - White
• EK Water Blocks EK-D5 Vario X-RES 100 (incl. pump)
• Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting Six Pack - Blue
• Mayhems Ice Dragon Nano Fluid 1L
• XSPC ECX Ultra Concentrate Coolant UV Blue
• Primochill Primoflex Advanced Tubing 16/11 - Clear
• Aqua Computer Kryographics for GTX 770 Acrylic Edition - Nickel x2
When i get around to putting it together, there will be another post, with some dodgy diagram of me still being scared of how to put stuff together
Thanks for the help.
