Wouldn't you be better off with a R9 290x? I mean they have half the VRAM but it has basically the same performance, you'd run out of grunt before hitting the limit.
unless you can find them super cheap; no; as the 390s and 390X have better power management; clock higher; memory clocks here; tends to run less power or the same with higher clocks and have even better cooling this time around
