Hello all
Long shot, but I'm after a cheap but worthwhile upgrade (i.e. significantly noticeable performance)over my old setup:
Current setup:
-Athlon X2 4400+
-2 x 1GB GSkill ram (DDR 400)
-NVidia 9800GTX (although I think there are newer versions of this or something?)
In short, I just want a nice but chirpy CPU/MOBO/RAM upgrade, that won't break the bank and I can upgrade at a later date is need be...There are obviously i3's, but would they be an improvement? If so, I could potentially do some testing with some 'old' kit I can use for a short term. Otherwise it's i5/i7 and i7's are wayyy out of budget I think.
So, any pointers?
I'll probably keep my graphics card for the interim, no it's not the best, but it should run most things half decently, and does currently.
x
Current setup:
-Athlon X2 4400+
So, any pointers?
x
