- 20 Oct 2008
The speed ratings on all wireless and Powerline connections are misleading. They're also factually correct and things aren't going to change.
I've got 500mbps Dlink ones with Gb ports and they max my 80mbps infinity fine.
Dividing by 8 does convert Megabits per second to Megabytes per second, but this isn't applicable in this case.
AV500 (500 Mbit/sec) adapters are likely to max out at around 70Mbit/sec (single stream), maybe a bit higher, maybe a lot less. Have a look at the information over at Small Net Builder http://www.smallnetbuilder.com/tools/charts/powerline/view for a better idea.
AV600 are worth a look; cheaper than AV1200 but still based on more modern chipsets than most AV500 adapters.
Hmmm, done a bit of reading on the 500Mbps adapters and a few people seem to think that if you divide the Mbps speed by 8 then you arrive at roughly the MB/s throughput (ie. 62.5MB for the 500Mbps ones)
Does this sound reasonable to the knowledgeable bods around these parts??
As long as the fibre speed isn't bottlenecked then I think I should be OK so the 1200Mbps plugs seem to be overkill!?!? (having said that, is there any benefit in going for homplugs with gigabit ethernet??)
