Tyre Damage - Is it ok?
20 Feb 2006
Noticed some tyre damage today and was wondering if it the tyre is still ok and safe or if it needs replaced.
I had looked about online and I think it might be ok because there is no cord showing, but I want to be sure.
Hmm... I think that is probably OK, how deep is the gouge?
I would replace it - probably not too terrible but I'd rather know the car was solid rather than worrying it was about to blow a tyre. Also the pressure looks a little low (may be wrong, esp if its the front).
I should say that my deepness estimates are probably cautious and it's likely not that deep. But I think it is better to be cautious with estimates such as this.
I would probably change that to be on the safe side. It looks like a pretty big chunk of the sidewall has gone.
Planning to get it looked at on Saturday if not sooner going by the responses on here which seem to suggest it should be changed as a precaution rather than a definitely bin it immediately as it's definitely unsafe / MOT failure.
Obviously it will have weakened the tyre. I had one like that once and had no issues. But then it wasn't quite that deep.
