Hi there
OcUK is having an INSANITY WEEKEND, we are doing two absolutely insane prices on to top graphics cards along with some aggressive pricing on other 980 lines.
These end Monday, so now is time to buy at these prices as for a 980 and 390 this pricing is insane!!!
Asus GeForce GTX 980 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £349.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1178MHz
- Core Boost Clock: 1279MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£429.95] Inc. VAT
Only £349.99 inc VAT - Upto £100 cheaper than competitors!!!!
ORDER NOW
Powercolor Radeon R9 390 8192MB GDDR5 PCI-Express Graphics Card (AXR9 390 8GBD5-PPDHE) @ £239.99 inc VAT
The 390 series from AMD offer great future proofing for upcoming game titles such as Star Wars Battlefront, DOOM, Half Life 3 and Fall Out 4. Featuring DirectX 12 support and 8GB of memory makes the 390 series great for current and future games at resolutions upto 4k.
The AMD R9 390 8GB features the latest GCN (graphics core next) architecture from AMD with 2560 stream processing units and an enhanced engine clock of up to 1010Mhz. It is equipped with 8GB of the latest high performance GDDR5 memory on a 512-bit interface and now clocked at 1500 MHz (6GHz effective) delivering higher bandwidth than earlier models.
Specification:-
- GPU: Grenada Pro
- Stream Processors: 2560
- Core Speed: 1010MHz
- Memory Speed: 6000Mhz
- Memory interface: 512-Bit
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 1x 8-pin & 1x 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£269.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 980 FTW ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2986-KR) @ £389.99 inc VAT
The new EVGA GeForce GTX 980 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1279MHz
- Core Boost Clock: 1393MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 1x 8-Pin & 1x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £389.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 980 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
GIGABYTE WINDFORCE 3X 600W cooling system once again break the record and bring the air cooling capacity up to 600W by only using 2 slots heights. The WINDFORCE 3X 600W cooling system is equipped with five 8mm and one 6mm composite cooper heat-pipes , special fin architecture, unique blade fan design, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
With GPU Gauntlet™ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching. Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Features:-
- WINDFORCE 3X 600W cooling system
- Flex Display Technology(patent-pending)
- Powered by NVIDIA GeForce GTX 980 GPU
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1228 MHz / BOOST: 1329 MHz
- System power supply requirement: 600W(with two 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1228MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: L=312mm, W=129mm, H=43mm
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
- Bit-Tech Review: http://www.bit-tech.net/hardware/graphics/2014/10/02/gigabyte-geforce-gtx-980-g1-gaming-review/1
Was [£398.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
A 980 at £350 is an incredible price and it really makes it the better buy over the 970 for sure as it offers considerable more horsepower and better 4k support.
Then the 390 8GB at £240 is absolutely insane, the 390 more than offers GTX 970 performance levels but with twice the VRAM and cost less now.
OcUK is considerably cheaper on 980 and 390 compared to competitors, but the prices are for the weekend ONLY, so in OcUK fashion spank those credit cards.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Specification:-
- GPU: Grenada Pro
- Warranty: 2yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
ORDER NOW
