- 24 Sep 2007
Hi Guys
Who provides the best home broadband at the moment?
Thanks
Thanks
I wish Virgin would remove the upstream management. I'm close to the cab, so went with fftc just for the upload.
I stream to twitch a lot, and would basically be constantly throttled by Virgin, in peak hours (exactly when I want to stream).
I think my area is ok though, so if they roll out 300 here and give decent upload with no management I'd probably switch.
Isn't that what he just said and the reason why he's not with VM?I would recommend Plusnet or BT. Virgin throttle at peak times
What if someone actually wants to upload something though? Virgin Media don't cater for that sort of insane niche usage.
Best I have used is BT infinity, been superb for me. Tried loads of different ISP's and they are by far the best imo.
Problem with BT - its good when its good, terrible when its terrible. If you have anything other than the most trivial of problems 99/100 you have to escalate it to the highest levels of the company to get it resolved which is a ridiculous waste of the CEO/ELC's time and your own.
Been with them 2 years and never had a single problem, connection has never dropped. Also had no issues with download or upload speed.
