Hi,
I currently have one of these and it was fitted under my carport and would only light up the drive so wouldn't really bother anyone however I'm tempted to use it over the drive especially with the thefts that are going on:
I've tried replacing the bulb before but quite frankly, it was a terrible incident. Bulbs are expensive + broke two trying to get it in
Does anyone know if it'd be easy and cheap enough to just replace the light part with an LED panel that would provide enough light for a normal drive without blinding the neighbours?
I've also got a cast iron old fashion light, would it be easy enough to link it to that and pop an LED bulb in?
