Anyone know of a place that can Laser Cut some mdf/wood near Birmingham?
Permabanned
19 Nov 2011
Hi,
Thought I'd post here incase anyone either works at or knows a place that can get some MDF or whatever Laser Cut if given the CAD drawings for it?
I'm planning on making a few things, but first off is a custom painting station for my miniature painting to keep it organised, next is a small table top arcade machine. I've got everything CAD'd up nicely and all dimensioned (CAD tech), but not sure where to get it sent for cutting. I'd do it by hand, but lack the tools and space to do it!
Does anyone know of a place that would take such a small order (only looking at maybe 1m^2 of wood) for a reasonable price?
Cheers,
Grady
You know depending on the atmosphere/humidity you keep it in you will get a fair bit of expansion/contraction on soft wood like that especially since you want sub mm accuracy.
Does it have to be near Birmingham? I do laser cutting, have large stocks of 3.2mm MDF and plywood, (as well as dozens of Acrylic colours). And will be able to price you for delivery. I can courier upto 31Kg for just £6. I would stick a link up, but don't want to fall foul of any rules!
