yeah dude i will when im happy with my overclock settings, to get going i would start by setting 44 multi, 100blk, leave ram at 2133mhz, leave cache at 3000mhz, set vccin to 1.95, vcore to 1.3 and cache to 1.15 run a custom prime95 tourture test put 448 in each box then set ram to how much ram in MB you want it to use, then let it run for 2 hours - if it fails in the first 20mins raise the vccin abit to 1.97 and retest, if it passes and you're happy with 2hour stable at those voltages move on to the vcore using 1344 custom sets, im pretty sure 1.95 will get you about 1hour stable if not longer. then do the same for vcore,imc etc etc... no easy solution im afriad it all depends on how much time you want to put in to your overclock. start of at a base, then test test and retest.
