Question for you cooling experts. I'm eyeing up the gorgeous Lian Li Pc-08 case for a new build, but the configuration of the front and rear chamber and where rads can go/ how and where AIO cooling tubes could pass through to the rear chamber space is confusing me big time.
I currently have one Corsair H55 set up on one my GPU's with a corsair n780 bracket. I'm planning to get another set like this for my other GPU and I will therefore have the following AIO cooled components (once a CPU AIO setup is added) as seen in the image below. Note this is not my case obviously and excuse the quick and dirty annotation...
Here is the image without the annotation:
Main questions are -
1. there is only room for a 240 rad at the top according to specs, so will 2x 120 rads, like on a corsair H55's fit here?
2. How will a CPU AIO cooler like a Corsair H100i fit where I've located it in the rear chamber? Will there be room/ a large enough gap to pass the tubing/ head around/ through, and fit if you remove the pre installed fans? And will the tubing on a H100i or similar be long enough??? Also I can't see how you would pass the pump head (part that attached to CPU surface) through to the back once the motherboard is in place?
NOTE: The design of this case is weird, as the fans/ possible bigger rad mount for front intake are located in the back chamber (intended for your PSU and drives etc).
3. Is there any other way of achieving my goal of 2x AIO cooled GPU's and an AIO cooled CPU? I guess I could sack the CPU AIO and get a v good air cooler? Would there be room?
And Please don't suggest a full custom water loop. I 'aint ready for that
