OcUK Staff
- 26 Nov 2014
- Stoke
Introducing the Raijintek Styx, a Micro-ATX version of the Metis with dual 240mm radiator support, 280mm VGA support, 180mm CPU Cooler support and more. Like the Metis, the Styx has an full aluminium exterior with the same finish and looks superb in the flesh.
The Styx is available in 6 colours, both in a windowed and 'classic' non windowed version. Stock is due to arrive in October and will be limited for the first delivery!
Raijintek Styx - Windowed - Black Micro ATX Case @ £64.99 inc VAT
STYX, RAIJINTEK's new aluminium Micro ATX case, has a remarkably elegant appearance and expansive compatibility with your PC system. STYX is compatible with standard ATX Power supply, max. 280mm VGA card and 180mm height CPU cooler.
STYX also provides a great cooling solution, with a 120mm fan pre-installed at rear, optional 2*120mm fan on top /side, optional 120mm fan at bottom and max. 240mm radiator cooling on top/side. Moreover, STYX offers a drive bay for Slim DVD on the side of the case.
With an entirely black coating inside and attractive aluminium colour hair-silk anodized appearance, the STYX satisfies not only your requirement for an elegant chassis, but also offers plenty of features and expandability too!
Features
- Aluminium colour hair-silk anodized appearance design
- Internal coated black throughout
- Compatible with ATX POWER SUPPLY
- Compatible with max. 280mm VGA card
- Supports up to max. 180mm height CPU cooler
- 2* USB3.0 ports
- Anti-vibration rubber for HDD installation
- Supports 3* 3.5"HDD +2*2.5"HDD/ 1* 3.5"HDD +4*2.5"HDD
- 120 mm performance fan pre-installed at rear
- Option to install 240mm radiator on the top/side and 120mm fan at bottom
- Large zone of ventilated holes for airflow on side panel
Specification
- Colour: Black - Hair-silk anodized
- internal color: Matt Black
- Dimension (D/W/H): 360mm*210mm*335mm
- Weight (N.W.): 3.8kg
- Weight (G.W.): 5.2kg
- Material: Alu. 1.5mm (external), SPCC 0.5mm (Internal)
- M/B Type: MICRO ATX/Mini ITX
- Power Supply: PS-2
- Power Supply Integration: ATX PSU; Vertically at bottom
- 5.25" Drive Bays: Slim DVD*1
- 3.5" Hidden: 1+2 (exchanged 2.5")
- 2.5" Device: 2
- I/O Panel: USB3.0 * 2; HD Audio x 1
- PCI Slot: 5
- CPU Cooler Height: 180mm max
- Graphic Card Length: 280mm
- Side Panel Style: Transparent Window
- Cable Management: Regular
- Front Cooling Fan: n/a, Rear Cooling Fan: 120mm*1 (pre-installed) , Left Side Cooling Fan: 120MM*2 or 240mm radiator (option) , Top Cooling Fan: 120MM*2 or 240mm radiator (option), Bottom Cooling Fan: 120mm*1 (option)
Only £64.99 inc VAT.
ORDER NOW
Raijintek Styx - Windowed - Red Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Silver Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Blue Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Gold Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Green Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Black Micro ATX Case @ £62.99 inc VAT
Features
- 2* USB3.0 ports
Specification
- 2.5" Device: 2
- PCI Slot: 5
- Side Panel Style: Vented
Only £62.99 inc VAT.
Raijintek Styx Classic - Red Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Green Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Blue Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Gold Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Silver Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Features
- 2* USB3.0 ports
Specification
- 2.5" Device: 2
- PCI Slot: 5
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Features
- 2* USB3.0 ports
Specification
- 2.5" Device: 2
- PCI Slot: 5
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
