- 24 May 2011
This post is a little late, so sorry for anyone that has been following my build. I'm quite happy with it, so I hope you guys/gals like it
First up, the component list! I've probably forgotten to add a few things as I basically bought everything new, from the keyboard and mouse to the mic you see in some of the pictures!
Case: Corsair 900D
Mobo: Asus X99 Deluxe USB 3.1 version
CPU : 5930k @ 4.6GHz and 1.285v
Mem: Corsair Dominator 16GB RAM 2800MHz
GPU : EVGA Hydro Copper 980Ti @1536/2003
HD : Samsung 256GB M.2 PCI-E
PSU : EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply with CableMod E-Series G2 & P2 Cable Kit - Black / White
Mic : Blue Snowball mic with arm and pop shield
Keyboard : CM Storm Quickfire Ultimate Keyboard - Brown Switch LED Backlit with Ducky Shine 4 ABS Backlight Compatible Keycaps White - UK
Mouse : EpicGear GeKKota Laser Gaming Mouse - White
Zowie Camade Mouse Bungee - White / Grey
OcUK Mega Mat Medium Elite Tactical Gaming Surface
Some of the watercooling and misc stuff - without quantities, for instance I bought 12 fans and quite a few Ghost compression fittings: -
Aqua Computer Aquaero 6 XT USB Fan Controller
Aqua Computer Front Bezel For Aquero 5 and 6 XT - Black
PrimoChill 240mm AGB CTR Phase II for Laing D5
PrimoChill Ghost Coupling for Acrylic Tubes 13/10mm
Bitspower 1/4 Inch Angle on IG 1/4 Inch - Carbon Black,
XSPC D5 Vario (Body + Screwring)
EK Water Blocks EK-Supremacy EVO - Nickel
Aqua Computer High-Flow Flow Sensor £27.49
Bitspower Extension Angle G1 / 4 Inches, 3x rotatable - Carbon Black
Mayhems Pastel - UV White Coolant 1L £14.99
EK Water Blocks EK-D5 Cover Kit (Nickel) Acetal
Thermal Grizzly Kryonaut High Performance Thermal Paste - 11.1g / 3 ml
PrimoChill 13/10mm Acrylic Tube 60cm 4-Pack - Clear
Bitspower Black Sparkle Mini Valve With Black Handle
Bitspower Adapter 90 ° G1 / 4 Inches, 2x rotatable - Carbon Black
Noiseblocker NB-eLoop Fan B12-P - 120mm PWM (2000rpm)
Mayhems Ultra Pure H2O 5Ltr
Revoltec Cold Cathode 10cm Twin V2
PrimoChill Revolver Compression Fitting Acrylic Tube 13/10mm Diamond 10-Pack - Black
Arctic Silver ArctiClean Thermal Material Remover and Surface Purifier - 60ml Kit
Coolgate CG480 480mm Radiator - Black
OcUK Air Duster Compressed Air (400ml)
Bitspower Plug 1/4 inches - Deluxe White
XSPC PSU Bridging Connector (24 Pin) £1.66
Koolance HX-480HL 11 FPI Copper Radiator - 480mm
Bitspower rotary fittings
Plastidip White spray
Lamptron UV light
PrimoChill 240mm AGB CTR Phase II for Laing D5 - Clear
Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm)
Gelid Solutions GC-3 10g Extreme Performance Thermal Compound
Probably missing a few things, but you get the idea
Here are some pics!
A few of the components in their delivery packaging pre-build
Some of the component packaging on display
Some of the peripherals on my desk including mic, keyboard etc
And the picture of the beast with white panels painted with Plastidip
Sorry for the quality of the pics! Hope you liked the build and thanks for all the help I got from OCUK and the folks in these forums!
Spike
Case: Corsair 900D
Lamptron UV light
Spike
