Thanks for the replies. So the hole spacing of my i7 950 (1366) is the same as the i7 4790k (1150) ?
I remember the cooler coming with two mounting brackets but I think the other one was for AMD.
1366 has wider spacing, 1150, 1156 and 1155 all have the same mounting holes.Thanks for the replies. So the hole spacing of my i7 950 (1366) is the same as the i7 4790k (1150) ?
Don't forget the newer CPU's are quite linear in one direction (usually top of mobo to bottom of mobo in a tower case IIRC - please check) - perhaps 50-60% taller than they are wide - so using the TIM "pea" method sometimes doesn't work well and often a "line" in the right direction will make more contact with the far ends of the core and cool better as a result.
The Broadwell desktop with the extra ram on the die is even more prone to this issue as the pea concentrates around where there arent any cores.
