17 Aug 2015 at 09:00 #1 MikeB MikeB Associate Joined 23 May 2006 Posts 1,774 HI All, Installed W10, love it personally despite odd moments of weirdness. Ordered a new SSD and wonder whats best clone software to use (That's free and works in W10) Cheers
17 Aug 2015 at 09:15 #2 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,079 you can try this guide http://forums.overclockers.co.uk/showthread.php?t=18576917 should work fine
17 Aug 2015 at 10:22 #3 MikeB MikeB Associate OP Joined 23 May 2006 Posts 1,774 top man will try it, sure I read somewhere that W10 doesn't clone well, but will give it a go when ssd turns up
17 Aug 2015 at 10:24 #4 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,079 you could do a clean install on your new SSD and then just copy over any files you need after unless you have loads of stuff installed etc. if you do a clean install make sure the new SSD is the only drive connected as sometimes windows may store stuff on the other drive
17 Aug 2015 at 11:07 #5 malachi malachi Soldato Joined 27 Jun 2006 Posts 13,072 Location Not here MikeB said: top man will try it, sure I read somewhere that W10 doesn't clone well, but will give it a go when ssd turns up Click to expand... Tried it with 3 of my Windows 10 computers. Worked fine.
17 Aug 2015 at 11:12 #6 Urbanfreestyle Urbanfreestyle Permabanned Joined 11 May 2015 Posts 456 Location Exeter, Devon I have used Easeus before and that worked great!
17 Aug 2015 at 11:38 #7 MikeB MikeB Associate OP Joined 23 May 2006 Posts 1,774 cheers all, chop chop delivery man!
