Hi there
If a graphics card was sexy this would be it, KFA's flagship WC product using BitsPower custom designed block, the aesthetics on this card are pretty stunning and as they bin the GPU's one can expect some very nice overclocks on these considering the custom water-cooling setup.
KFA2 GeForce GTX 980Ti "Hall of Fame WC Edition" 6144MB GDDR5 PCI-Express Graphics Card (98IRH5DHH3WT) @ £719.99 inc VAT
KFA2 Hall of Fame edition cards are born from top quality components and exemplary innovation to achieve one sole objective—to break records. The KFA2 GTX 980 Ti HOF exemplifies this and sets the definitive standard as the world’s best GTX 980 Ti graphics card.
Working in-conjunction with Bitspower, KFA2 has developed a water cooling solution designed to fully unleash the raw potential of the GTX 980Ti HOF graphics cards with the unprecedented cooling capacity needed for extreme overclocks.
Features:
- VR Ready
- DirectX 12 Ready
- VR Ready
- 6144MB VRAM
- Custom waterloop cool required!
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1203MHz
- Core Boost Clock: 1304MHz
- Memory Clock: 7010MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 2yr
Only £719.99 inc VAT.
ORDER NOW
Features:
- VR Ready
- DirectX 12 Ready
- VR Ready
- 6144MB VRAM
Specification
- GeForce 980Ti
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 2yr
ORDER NOW
