Dressing they put in wounds (packing)
Are you not going to your local GP clinic to get this changed anyway?
They will give you dressing etc or at least tell you which ones to buy.
BB x
He's asking for specific information on a specific medical application of something medical for reasons unknown. Sorry I disagree which I know means nothing as you guys enforce it all but just saying all the same. :)
I'm not asking for medical advice am I? nor am I asking for anything specific! I just wanted to know what doctors/nurses stuff into wounds and why, am not looking into stuffing something into myself or anyone else, if I wanted to I can ring my doctor up and just ask.
I can start a thread asking what a triple bypass surgery does and how they do it, doesn't mean i'm seeking medical advice or looking to operate on myself or anyone else!
gauze ? tampons for bullet wounds?
Gauze was originally made of silk and was used for clothing. It is now used for many different things, including gauze sponges for medical purposes. When used as a medical dressing, gauze is generally made of cotton. It is especially useful for dressing wounds where other fabrics might stick to the burn or laceration. Many modern medical gauzes are covered with a plastic porous film such as Telfa or a polyblend which prevents direct contact and further minimizes wound adhesion. Also, it can be impregnated with a thick, creamy mixture of zinc oxide and calamine to promote healing
your local chemist can give advice if you really have a medical issue like a boil or something.
Deep wounds are packed so that they don't heal at the surface but leave a cavity underneath which will have a high likelihood of re-infection or other complications.
Packing it (often with a antimicrobial dressing containing silver such as Aquacel AG mentioned above) holds the would slightly open along its 'depth' and at the surface so it heals from the bottom. The packing is changed daily or every 2-3 days and the amount of packing is gradually reduced so it will eventually heal up towards the surface - sometimes over several weeks (or even months).
How do they actually heal inside, as in form together if it has packing which is keeping it open? and seemingly stopping the two sides of the cut wound rejoining.
Aquacel or Sorbsan ribbon. Usually just pack them in dry.
You pack an abscess to let the tissue heal from the outsides of the abscess in, the packing also keeps the hole open and remove foreign material. If you don't pack a wound the hole may close early leaving a cavity which can become an abscess again.
Your answer I said is specific to the type of wound. There are various ways to do it that are appropriate for a variety of situations. One may be sensible in one case and not in others. Moreover, there are ways to do things and the best way to do things. Like I said in my initial post you won't get the correct answer to this unless you ask a specific question. You could ask generally and you have had general answers but they may or may not be wrong for specific cases.
If you really want to know then you need to be exact in your question and whom to ask. I know where to look for the right answer and I could as eg Minstadave, has done give you a general answer, but if you want to know the correct answer ask a specific question to a tissue viability nurse or a trauma nurse not a doctor or someone who deals with these things now and then. Nurses have forums too, ask on a US, UK or Aus/SA/NZ one. Or alternatively look in the tissue viability journals that are easily accessible for academic access if you have that.
Personally I don't care whether it's a medical thread or not. My posts are not so much for you but more to highlight what I feel to be very inconsistent mod actions on such threads. The close down some threads where people need help (that is their choice) but then let other stuff stand on the same rules even if there is no real issue (eg this thread) and then seemingly never have a problem with other stuff. I just find their stance very very inconsistent. Nothing to do with you or this thread really.
Gauze /thread!
it depends on the wound, where it is and what has happened
lots of different options
aquacel
aquacel ag
kaltostat/algosteril
ribbon gauze
foaming stuff used for pilonidal abscesses that i forget the name of
no mustard however
You have to make sure it is packed tightly though with Aquacel.
As the wound heals it pushes the packing out.
Sometimes the wound can heal 'too well' and you get overgranulation in which case you will need to use silver nitrate to get rid of it.
However, at that stage you should be getting the dressing changed in the GP clinic to lessen the risk of any other infection.
BB x
Didn't superglue get invented by the Americans during Vietnam or is that just an urban myth?
Bit of both. It was invented in the 1940s but was used by the USA military in Vietnam as an emergency wound sealant (and it works for that purpose).
the bottom heals together so it gets "shallower" every day and the packing is reguarly replaced.
