just installed windows 7 now it wont boot into windows!!
20 Oct 2002
Oxfordshire / Bucks
just put my new skylake stuff together, installed windows 7 64 on my ssd, which is connected to my msi z170A gaming pro motherboard
installed windows 7 fine
rebooted now I cant get past the bios, it says "Reboot and select proper boot device or insert boot media in selected boot device and press a key"
In the bios options change the boot device to the HDD you've just installed W7 on.
tried that, didn't work
do you have an ssd and hard drive installed ?
have you disconnected the hard drive since install ?
yes 1 ssd and a few hdd's
I did try the ssd in the other slots as 1 hard drive doesn't work in slot 5, but put the cables back to where they were
makesure your ssd is first boot device in the bios,if it still displays that msg then boot from windows disc and do a startup repair,that should fix it
after I installed windows I changed the boot order s that ssd was first, same problem, so ive reinstalled windows and going to update it and se if that works
