Windows 10 insider builds
Man of Honour
11 Mar 2004
Thought probably best to keep this separate.
Now initial release is done we are back to getting builds, Build 10525 is out on Fast ring, though not showing for me, wonder if that's due to uk language, see known issues.
Two main things
Updated color options!
We got a lot of feedback on the default color for Start, Acton Center, Taskbar, and Title bars and that you wanted to be able to change to reflect your preferences. This feature is now available (though still early) in build 10525 for you to try. This is off by default, but you can turn it on by toggling this (Settings > Personalization > Colors):
Memory Manager Improvements:
In Windows 10, we have added a new concept in the Memory Manager called a compression store, which is an in-memory collection of compressed pages. This means that when Memory Manager feels memory pressure, it will compress unused pages instead of writing them to disk. This reduces the amount of memory used per process, allowing Windows 10 to maintain more applications in physical memory at a time. This also helps provide better responsiveness across Windows 10. The compression store lives in the System process’s working set. Since the system process holds the store in memory, its working set grows larger exactly when memory is being made available for other processes. This is visible in Task Manager and the reason the System process appears to be consuming more memory than previous releases.
We do have a few known issues with this build.
Part of the fun of being a Windows Insider is getting to tinker with prerelease software before the rest of the world, but you should be very aware as an Insider that prerelease software will come with bugs and things that are incomplete. Make sure you know and accept what you’re opting in to when you join the program, and of course make sure to back up all of your personal data before you begin.
•Mobile hotspot doesn’t work in this build. When sharing the Internet from your device with mobile broadband using Mobile Hotspot, it will fail to get a valid IP address from your device and will show no internet access.
•An update to Movies & TV application from the Store will be required to fix an issue with video playback.
•Optional languages packs will not be available during the initial launch of this flight, it will be available later this week.
I’m very excited to be able to officially welcome you to the next phase of the Windows Insider program and bring you a new build today. I hope that you have fun with it, and be sure to keep sending in your feedback via the Windows Feedback app!
Would you look at that, first build after the initial release and they are already implementing things based on the feedback and suggestions people have made. Thats a good sign.
Yeah I got it but it doesn't like geforce, gpu-z or riva for some reason. I posted on another thread I started earlier in the software section. Completely missed the fact W10 had its own header now.
Also in my laptop it is preventing me connecting to tinterweb citing not being able to detect proxy. Refreshing both desktop and laptop and opting out of the insider builds in future.
Hmm weird I've had that option for awhile (only just updated to 525 - only difference is it didn't do titlebars without an aero hack) was expecting something different. Without window border transparency, etc. though it looks kind of naff IMO in most cases as per my previous screenshot:
http://i.imgur.com/OGAh9z9.png
Though if you are a fan of neon colours then it does sort of work with bright pink, etc. on the task bar but that totally isn't for me.
EDIT: Looks like they might have enabled it for testing for some users before.
Does anyone else receive this message yet in Windows 10?
Windows isn't activated. Activate Windows Now.
My Windows 7 was fully activated before I upgrade to Windows 10. Now it is asking me to change the product key.
Argh - not something that can't easily be undone but with this update to 10 all my 8 and 10 systems using the same account have suddenly started using synced theme settings - which doesn't work at all.
Obviously can deselect synchronized theme but it messed things up proper on my windows 8 tablets.
