20 Aug 2015 at 00:06 #1 Rotty Rotty Don Joined 18 Oct 2002 Posts 42,153 Location Notts IE 11 just seems to eat and eat memory >1GB after some time, it just keeps rising until it starts playing up Most things I have seen refer to add ons so I disabled all those but it's still a problem any ideas?
20 Aug 2015 at 06:23 #2 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton Have you tried a reset ? queue the use chrome or firefox lol
20 Aug 2015 at 12:09 #3 Vengance Vengance Associate Joined 23 Oct 2006 Posts 948 Location Aylesbury ShakenNstirred said: Have you tried a reset ? queue the use chrome or firefox lol Click to expand... Edge!
20 Aug 2015 at 14:41 #4 markweatherill markweatherill Soldato Joined 16 Jun 2009 Posts 2,566 Location Bucks Vengance said: Edge! Click to expand... This is madness!
20 Aug 2015 at 15:56 #5 Rotty Rotty Don OP Joined 18 Oct 2002 Posts 42,153 Location Notts by reset do you mean uninstall and reinstall?
20 Aug 2015 at 16:04 #6 Nate75 Nate75 Soldato Joined 21 Mar 2005 Posts 13,903 Run yourself a quick AV scan.. http://www.eset.com/us/online-scanner-popup/
20 Aug 2015 at 18:12 #7 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton Rotty said: by reset do you mean uninstall and reinstall? Click to expand... No, in the options there is a reset setting, maybe that will help. also how many tabs do you have open, the more open the more ram used
