Phanteks Enthoo Luxe Full Tower Case - White @ £119.99 inc VAT
Staying true to the Phanteks’ Enthoo line, the Luxe features a sandblasted front and top panel. Ambient lighting runs from the top to the front of the case on both sides.
Even though smaller in size, the Enthoo Luxe boost many features from the award-winning Enthoo Primo.
The Luxe comes pre-installed with a 200mm front fan and 2x PH-F140SP fans. Phanteks’ Enthoo
Luxe has an extensive watercooling capabilities that allows for four different radiator mounting
locations as well as sizes.
Styling Features:
- Clean and elegant design from the Enthoo series
- Sandblasted aluminum faceplates with matte finish
- Multi-color ambient lighting
- Stealthy interior design
Features:
- Dual removable harddrive cages
- Closed HDD panel
- Removable Drop-N-Lock SSD brackets
- Fully equiped with dustfilters (1x top, 1x front, 2x bottom)
- Removable top mesh panel for easy fan installation + dustfilter cleaning
- Clean cable management using Phanteks’ pre-installed Hoop-N-Loop cable ties + Removable PSU cover
- Ambient lighting with LED on/off switch and color control (10 colors)
- Modding friendly structure - fastened by screws instead of rivets (removable top/odd/hdd panel)
Specifications:
- Dimension: 235 mm x 560 mm x 550 mm (W x H x D)
- Form Factor: Full tower
- Material(s): Aluminum faceplates, Steel chassis
- Motherboard support :ATX, EATX, uATX, SSI EEB
- Front: I/O 2x USB 3.0, 2x USB 2.0, Mic, Headphone,
- LED: switch
- Side window: Yes, split-window design
- Expansion slots 8
- External 5.25” 3
- Internal 3.5” 6 (2x 3HDD cages)
- Internal 2.5” 8 (2x on SSD brackets)
Liquid Cooling:
- Front Up to 240
- Top Up to 360/420
- Rear 120/140
- Bottom Up to 240/140
- 5 Year Warranty
Only £119.99 inc VAT.
ORDER NOW
Corsair H60 Bulk Cooler [CW-9060007-NA/BULK] @ £29.99 inc VAT
Make the Move to Liquid
Upgrade from your stock CPU fan or bulky air cooler to the efficiency and simplicity of liquid CPU cooling. Enjoy better cooling performance and lower noise, and protect your investment in your CPU.
Advanced Fan Design
The 120mm fan incorporates custom-engineered blades for better static pressure to noise ratio, offering improved performance at lower noise levels.
Only £29.99 inc VAT.
ORDER NOW
Styling Features:
Features:
- Closed HDD panel
Specifications:
- LED: switch
- Expansion slots 8
- External 5.25” 3
Liquid Cooling:
- Front Up to 240
- Top Up to 360/420
- Rear 120/140
- 5 Year Warranty
ORDER NOW
Advanced Fan Design
ORDER NOW
