Was reading recently a description of an interesting experiment that you can actually try at home.
Pick a dark room with a single light source (say a table light)
Close one eye and hold your hand up at arms length so that you are looking at the light through the gap between your first finger and your thumb.
Bring your finger and thumb closer together.
Now, it takes a bit of practice, but if you get it right there will come a point where, in the gap, there will be a dark band with light on each side of it.
This is not some sort of mere optical illusion. You are actually looking at the consequence of interference patterns cancelling out the light!
I just find it remarkable that it is actually possible to demonstrate optical diffraction effects using only your fingers, a convenient light source and the Mk1 eyeball!
