Hi
Been looking in the BIOS for the above board and I can't seem to adjust the "CPU ratio". It just says "auto" and I can't see anyway to change it manually! Seems a bit odd. Normally just have to highlight it and press return and then select / enter what you want. Just doesn't seem to be any way to change it.
IE. Auto is not in square brackets (IE.[auto]).
Even stranger, as I've been playing around with the Intel Extreme tuning utity and that seemed to allow me to change it.
Any ideas???
Any ideas???
