Cheap Watercooling Closed Loop
2 Jul 2015
Hampshire
Hi,
I have an AMD FX8350 and an Asrock 980DE3/U3S3 MOBO. I am looking for a cheap closed loop water cooling system for my processor only. I would like suggestions on the cheapest options available because I'm on a tight budget. If you need more info let me know.
Your budget would help.
Your case too.
My case is a CiT Apache Case (I know, I was on a budget) and my budget is basically fairly low. I do not know much about water cooling systems as I have only used air cooling before. I would just like a simple closed loop system. I was also wondering what ports I would need on my motherboard. I was wondering how many fans will need to go into the MOBO.
Thanks
It says you have space for 2x120mm fans at the top of the case. Are the fans next to each other? If they are, this is the cheapest option for a 240mm rad AIO. But if you can stretch a little more, you can get some quality stuff for under £80
Thank you. That looks like a very good option. I will read up more about that unit and see if there will be any compatibility issues.
