Yes it's impressive to see ye old 290x doing so well there but why haven't they included the Fury results.
Yeah is odd that, Fury X would have been great to see. Especially considering the old 290X is taking on and winning some against the Nvidia 980 Ti.
It's almost as if DX11 has been artificially hobbling AMD cards?
Anyone noticed how similar the spec of 980 Ti is to the old 290X?
Same GLFOPS...
His last strike (I'm on mine too, although mine are more for destroying Humbug on a daily basis) means he'll lose access to the Graphics card section, mainly for arguing with fanboys such as yourself.
I'm not really a fanboy, just someone who likes to support the underdog. If Nvidia was in AMD's position I'd support them too, as long as they supported open standards though. I'm also a cheapskate who likes to promote competition so I can get cheaper gpu's![]()
Given everything I've ever seen you post, you're a cut and dry AMD fanboy.
I actually did buy a gtx970 last year (returned after memory debacle thanks to OCUK) which any fanboy wouldn't even consider.
So that makes me not a fanboy then in your book![]()
I see AMD as the underdog at the moment. Also have you seen me go into Nvidia threads to troll which is what all the Nvidia fanboys do regularly?
I will point out stuff which Nvidia fanboys don't like and I absolutely hate Nvidia practices such as the closed libraries, refusal to take returns during the gtx970 debacle, etc which may make me look like a fanboy.
Funnily enough you consider MMJ a hardcore fanboy, he's done something I wouldn't even entertain ; Purchase an own an FX83.
I see you do a lot of trolling.
A lot of talking about a subject you know nothing about go give praise to AMD etc.
I have an AMD 290X, it doesn't make me think any lesser of AMD as a company. But I don't think anything of Nvidia either.
I wouldn't mind having fun with the names Greenland, Baffin and Ellesmere but fear I'll be told off.
Anyway here's hoping for some healthy competition moving forward between the two companies and more good options for the consumer.
Don't start that again mate. If you 'think' you know so much about what Freesync in the other thread, then explain rather than accuse others of knowing nothing.
Edit: also I thought said you weren't going to reply to my posts.
How can one argue with this.
And I don't pretend to know more than I do. It's very clear that adaptive sync isn't freesync, they're each an ingredient. Adaptive sync is what allows freesync to work, it's that simple.
At the end of the day a Freesync monitor is essentially an Adaptive sync monitor so Intel will be able to use it with their software/hardware without paying AMD. They can also use the Freesync name without licensing or royalty fees if they decide to.
Do you agree on that point?
I keep trying to make the point..Freesync is just the branding name for AMD's implementation of Adaptive sync.
At the end of the day a Freesync monitor is essentially an Adaptive sync monitor (due to VESA standard) so Intel will be able to use it with their software/hardware without paying AMD. They can also use the Freesync name without licensing or royalty fees if they decide to.
Intel can't use the Freesync name unless they have permission from AMD. Freesync is AMD and G-Sync is Nvidia and Intel would probably use I-Sync or something like that.
You are confusing things.
