Been over 5 years since I built my current PC and now upgrading to Skylake (and Windows 10). Looking to build a new PC that will last 5 years in terms of performance and technology.
Currently have:
Samsung 913N
Antec 300 case
Corsair HX 650W Pro Series
Gigabyte MA770T-UD3P ATX
AMD Phenom II x2 555 Black Edition
Artic Freezer 7 Pro
Corsair XMS3 2 x 2Gb DDR3
Sapphire Radeon HD 5750 1Gb GDDR5
Samsung 500Gb SATA drive
Already replaced the ageing Samsung 913N monitor with a Dell U2515h this week.
How does the following Skylake build look ?
Antec 300 case (from current build)
Corsair HX 650W Pro Series (from current build)
Samsung 500Gb SATA drive (from current build)
Intel Core i5-6700k or i7-6700k
Asus Z170 Pro Gaming Intel Z170 ATX
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz
Samsung SM951 256Gb M.2 PCI.e ACHI SSD
Be Quiet! Shadow Rock Topflow SR1 CPU Cooler or Cooler Master Hyper 212 Evo CPU Cooler
I have deliberately not included a graphics card as I do not currently game. I may try some games using the GPU and if I need to buy a dedicated card then I will do so at a later date, though it will just be one, however I may try the HD 5750 that I have already but have a feeling this would be pointless as it further down the graphics hierarchy than the GPU ?
I would have gone for another Gigabyte motherboard but there is not much availability, besides the ASUS look like better bang for buck.
I have looked a loads of different air coolers and have narrowed it down to one of two having decided that I wasn't going to pay 60-70 for a cooler! Which of these would be the best option in terms of temperatute and quietness ? Open to alternative suggestions up to £50 max. Current PC is noiser than I would like so this is an area that I would like to improve on and I have a feeling that it is the graphics cooler that is noisey. I may end up replacing all the fans in the case later.
Planning to use the PC for doing work, a bit of programming, Oracle, running 4-5 Virtual machines at the same time with Solaris and Windows Server. Not sure whether to splash out the bit extra for the 6700k ? Don't want to go for the 6600k and have to upgrade again, not for another 5 years anyway !
Not sure if I would be over doing it with the 3200Mhz memory ? I am definitely set on 16Gb because of the VM's.
Not planning on overclocking until a few years down the line.
Currently have:
Samsung 913N
Antec 300 case
Artic Freezer 7 Pro
