Stuck in the bath? Drape a towel over the edge so the spider can crawl out and then shake it off outside
Coax the spider onto a long stick or ruler and take outside. Vacuum up old webs
The spiders, which can grow up to 12cm in length
I won't be doing any of the above to a 12cm monstrosity
Another non-story by the BBC.
That's a lid from a CD-R spindle for reference. Also it has a leg missing. Dem mandibles doe..
My hand held Dyson is great for extracting spiders and other bugs. They come out a bit Dizzy but unharmed.![]()
Still recall one night I was happily browsing the forums when I heard a tapping noise coming from the PC case. I figured a cable might be hitting one of the fans so opened up the case to inspect.
It was a spider, the fan's airflow was causing the web to bounce and the spider tap against one of the blades. It's a wonder the bigger didn't get chipped up!
Put tights over the end of the hoover, suck it up and then the hoover off outside the window/door![]()
