I have two optical drives connected by a 100/133 cable to the motherboard (ASUS PSK SE/EPU). The cable seems to be of reasonable quality (round, shielded, contained in a thick heat shrink).
Neither of the optical drives are recognised by the computer in Devise Manager. They just don’t appear. No yellow triangle etc.
When the computer boots only the light on primary drive lights up, the secondary drive doesn’t.
I’ve dabbled about a bit following the Windows Wizard which suggests disconnecting drives etc, etc. I also did the bit about creating a key in the registry.
If I unplug the ATA/100/133 cable the lights on both optical drives will light up and the trays will open. When I replace the cable, the primary drive will open and close, but the secondary drive will neither light up or open and close. I reboot between each dabble and I’ve been unable to have windows (XP) recognise the drives.
Does anyone have any ideas, could it be the socket (unsure of the name) on the motherboard (red coloured if that’s any help) has failed or the ATA Cable. I don’t have a spare ATA cable.
I also tried, and I don’t know if it would work if I was doing it correctly and that was to omit the secondary drive altogether, going straight from the motherboard socket direct to the primary drive. I also tried direct from motherboard to secondary drive using the primary drive connection.
Some time ago the Ethernet cable socket failed (lightening strike, surge up virgin cable me thinks), following sound advise from guys on OCUK I bought an Adapter Card and its now working.
I was unable to use system restore. I think the problem might have been after I'd uninstalled a freeware video to mp4 conversion program. I only discovered the problem some months later.
Both optical drives are Sony and work from Windows drivers.
I am intending to buy a new computer with windows 10 installed and I’d like to pass this one on to my niece as a standalone computer. As it stands its impossible for me to reinstall the operating system.
Any suggestions would be warmly welcomed.
