Fittings for acrylic tubing
Good choices.
Is there a dampening or cushion for the PrimoChill 240mm AGB CTR Phase II for Laing D5?
IE to dampen vibrations from the pumps?
Good choices.
Im not sure to be honest i don't think that it will be on the bottom of my case though. Im planning on mounting the res to the side, that may reduce the vibrations as the pump itself wont be touching the case.
Or is that a bad idea and should the pump make contact somewhere?
Would suggest you get a bending kit. Ek do a kit which you will need if you want to bend tubes
I have a heat gun, also a rubber bend cord, and ill look to see if i can get the bending blocks from somewhere. £30 is a little pricey.... Also they're out of stock currently.
If you are placing it vertical or horizontal the pump still spins and causes vibrations, ie noise.
You can slow down pumps to lower the noise.
But I'm just wondering if there is something like the Shoggy Sandwich to place between and dampen the vibrations.
