- 29 Oct 2014
- Chesterfield, UK
Ohh wow they look awesome! You got any idea on what ones are quiet but good performance?
Err... all of them?Ohh wow they look awesome! You got any idea on what ones are quiet but good performance?
The PE's probably say 'High Pressure, Low Noise' on the packaging, but the latter part is very often NOT the case!!!
Corsair H100 w/2 x SP120 PE in either push or pull, housed inside a Corsair Carbide 500R.Interesting, as I have these fans currently p/p on an H100i GTX cooling a 3970X running around 1900rpm (all 4) via C Link. I'd have to say, acoustics is not that all terrible.. I can barely hear them on that rpm. Tone them down to 1400rpm, and they are whisper quiet.
The NF-P fans (beige and redux) are reasonable in terms of performance through radiators, but they are notably noisier on higher settings than NF-Fs would be.Adding about the Noctua Redux, they only have airflow fans, no Static Pressure fans that are ideal fans for radiators, CPU coolers etc which is a shame
I have the SP120's in my system and they are very nice not totally silent but not to loud under load either.
I'm having all sorts of trouble using SP120 PWM quiet editions on my H100i.
was hoping to stay away from using the Corsair Link software and connections.
I have 4 of these on an H100i.
On my old Asus P67 board linked to an Akasa 5 way PWM splitter they were near silent on idol when cooling a 2600K @ 4.5Ghz. On full load they were pretty good noise wise too.
However I've just moved to an EVGA X99 Micro2 motherboard and using the same PWM splitter setup, I cannot get the fans to run at less than full speed.
I'm reading various articles on the web that the SP120s have known issues when running on PWM splitters.
I've connected only 1x SP120 to the CPU header to see if this works ok on PWM and it did.
So now I'm looking to try 2 x 2 way splitters on 2 headers to see if that works better.
Nice fans, just be aware there can be issues when using PWM splitters with them!
