Windows 8.1 to Windows 10
12 Dec 2005
I've just installed a brand new copy of windows 8.1 and activated it using the key - How do I find out what version of windows 8.1 it is - On the packaging it just says 'full'
How can I upgrade to windows 10 with this now ? Can I just download an ISO of windows 10 and use my windows 8.1 key
Just go to MS site and dload the installer and then select upgrade.. Win10 will assign it some sort of checksum that locks it to your motherboard but you will not retain your original 8.1 key as far as I'm aware..
As long as you remove the USB stick when it says setup begins you won't be prompted for a key. I did it this way and didn't need my key..
I was trying to update using a win 10 I had on a usb but I think I need to let the tool go through and download it that way
If your being prompted for a key you aren't upgrading, and therefore doing it wrong.
Log into 8.1, run the tool, select upgrade.
