which card?
22 May 2011
All over the place
Planning an i7 Haswell build which will be used for music editing, CAD and some gaming.
The gaming I will be doing is going to be things like Assassin's Creed, some FPS, driving games and only on a single 1080p monitor. I have been thinking about a GTX980 but is this going to be overkill for my needs?
Really have no idea what to get to be honest. I don't really want to spend >£200 but don't mind going second hand
Sounds like a mid-ranged card such as GTX960 or an R9 380 will do you nicely; they start at around the £150 mark.
Something like a second hand 7970 or 280X (essentially a 380) is also an option, as is a GTX670.
What about a 780ti? Or is that still overkill?
It depends what kind of performance that you expect out of your hardware. If you want to crank up the detail on all titles, then no, I don't think it would be an unwise purchase.
I don't know what second hand 780ti's go for, though I would think it's 'around' the level of your budget.
Personally, I'd get this from somewhere, perfect 1080P card and excellent free game, that you could sell. Future proof, quiet and bloody fast @ 1080p. I had one before I went 4K.
I would quite like to be gaming with decent details so I'm definitely considering this. They do go around about £200 second hand
I've also been looking at these! What makes a card 'future proof'?
A quote "The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture"
If it can run Witcher 3 Maxed out(without stupid hair option) @ 1080P now, it'll run anything for the next 2 years at a very high level. Basically, like it or not, the current gen consoles dictate to a degree the quality of PC game releases, and Witcher 3 is very demanding.
better go for r9 390 instead of gtx 970 8gb memory and a little bit faster for less price :D
Never tried the r9 390 but have heard good things. Perhaps this is the card to go for, do a bit research on this and the 970gtx OP as this guy could be right, I'm just speaking from 970gtx experience.
Cheers, is this all in regards to the 970 in general or is that Gigabyte one particularly better than others?
It's just the one I used. It's stock clocked and I would guess it will be faster than a vanilla r9 390, plus you get the free game.
You can get a vanilla 970gtx cheaper than a r9 390 and do a little tweaking yourself.
EDIT: There's an overclocked 970 gtx for sale at the river place for £259.99 with the free game, due in stock on the 30th.
