Hi Guys
Finaly they made it happen!
After 2 years developing a 140mm model from their existing 120mm model.
The 140MM eLoop fans will sell quick. Perfect for cases, CPU coolers and Radiators.
We will have stock in around 7 days.
Brilliant!
Noiseblocker NB-eLoop Fan B14-1 - 140mm @ £17.99 inc VAT
Hightech compact fans with bionic loop rotor (BionicLoopFan®). The special wing shape triggers turbulence in the air. This physical effect reduces the volume which is based on turbulances in the air flow and reduces energy consumption. With a straightened air flow and a higher Airflow these fans usually offers a higher overall cooling capacity over classical fans .
Features:
- 100% developed in Germany
- TÜV-certified sound level specifications = real data
- Extremely low-noise bionic loop rotor
- position-invariant magnetic bearing NB-NanoSLI® 2NEW!
- silent NB-EKA P2 Drive NEW!
- Bayer® Makrolon® rotor with anti-dust technology
- weighted reinforced fibreglass PBT frame
- NB cable management with two pluggable connection cables
- Perfect results for PC casing, CPU cooling systems and radiator( higher cooling power at same revolution ratel)
Includes:
- 4 fine thread screws and knurled nuts for tool free assembly
- 4 NB silicone slics for vibration-free assembly
- each 2x 20 and 50 cm connection cable with textile sheath
Dimensions: 140 x 140 x 29 mm
Volume: max. 5.71 dB (A)
Speed: max. 600 U / min
Airflow: max. 73,63 m³ / h
Starting voltage: 5V
Power consumption: 0.24 W
Connector: 3-Pin
Life expectancy: 160,000 hours
Warranty: 6 years
Only £17.99 inc VAT.
ORDER NOW
Noiseblocker NB-eLoop Fan B14-2 - 140mm @ £17.99 inc VAT
Features:
Includes:
Volume: max. 16.95 dB (A)
Speed: max. 900 U / min
Airflow: max. 109,22 m³ / h
Starting voltage: 4.5V
Power consumption: 0.66 W
Connector: 3-Pin
Warranty: 6 years
ORDER NOW
Noiseblocker NB-eLoop Fan B14-3 - 140mm @ £17.99 inc VAT
Features:
Includes:
Dimensions: 140 x 140 x 25 mm
Volume: max. 28.5 dB (A)
Speed: max. 1,400 U / min
Airflow: max. 178.29 m³ / h
Start voltage: 4 V
Power consumption: 1.92 W
Connector: 3-Pin
Warranty: 6 years
ORDER NOW
Noiseblocker NB-eLoop Fan B14-PS - 140mm PWM @ £17.99 inc VAT
Features:
Includes:
- Volume: max. 24.28 dB (A)
- Speed: max. 1,200 U / min
- Airflow: max. 142,59 m³ / h
- Starting voltage: 5V
- Power consumption: 1.44 W
- Connection: 4-pin PWM
- Life expectancy: 160,000 hours
- Warranty: 6 years
ORDER NOW
Brilliant!
Features:
Includes:
Connector: 3-Pin
Warranty: 6 years
ORDER NOW
Features:
Includes:
Connector: 3-Pin
Warranty: 6 years
ORDER NOW
Features:
Includes:
Start voltage: 4 V
Connector: 3-Pin
Warranty: 6 years
ORDER NOW
Features:
Includes:
- Warranty: 6 years
ORDER NOW
