Hi,
I'm interested in learning more about fans. I've currently got 8 120mm fans in my moderately OC'd machine:
2 fans in the front/bottom of the case
1 fan in the bottom of the case
1 fan on the back of the HDD compartment
2 fans on the CPU cooler
1 fan on the top of the case
1 fan at the back of the case
All fans except for 1 are Scythe SY1225SL12SL. My machine is a little on the loud side! It's not excessive, but I'm looking to reduce noise as much as possible. I have an NZXT Switch 810 case.
Also, I do currently have a fan controller. It's a basic slider one and has only six sliders, so a couple of the sliders control 2 fans.
Questions:
1) Should I look for the lowest DB rating (e.g. these are 6.9DB http://www.quietpc.com/nf-s12b-redux-700), or should I be looking for fewer fans, with greater airflow, but which have a louder DB rating?
2) Am I best to look for a better fan controller?
3) To ensure the fans are placed correctly, which way round do the fans point? I heard one time that the side of the fan with the label in the middle is the side that the air comes IN at, is this correct?
Thanks
Questions:
Thanks
Wouldn't be able to tell if it was a snake or a bird flapping it's wings.
